Tire rack wheels
Old Dec 18, 2009 | 03:24 AM
Slick Dakota's Avatar
Slick Dakota
Default Tire rack wheels
Hey guys think I will have any trouble running these wheels because of back spacing and the offset? offset -13mm back spacing4.52 bolt pattern 5-139
I am going to run down the stock tires for a bit then do a few other projects on the truck then get these wheels and rims.. I ordered my TM leveiling kit last night and picked up the 2" lift blocks from advanced auto today looking forward getting on that project in two weeks.. I also been reading thru all the posts about shocks and how Ranchos don't have them for my 07, so I guess I will be going with monroe..
my stock wheels are 18x8 nearly the same size as these 18x9 wheels and tires size is the same as my stock ones 265/60/18 same as the bridge stones I will be buying.. Tell me what you guys think of this combination?
http://www.tirerack.com/wheels/Wheel...heelModel=DC-1
http://www.tirerack.com/tires/tires....a+Quad+Cab+4wd
Old Dec 18, 2009 | 08:21 AM
canadiandodge's Avatar
canadiandodge
i like the combination and i have 18 by 9 on mine right now and am fine i put 265 65 18 with no lift on or anything. i have a lift now and wish i went bigger
Old Dec 18, 2009 | 11:58 PM
biker_ahoy's Avatar
biker_ahoy
The Ranchos are available for the 07, its the same as the 05-06. setup. just look for or ask for the 05's! they do have them.
Old Dec 19, 2009 | 02:18 AM
Slick Dakota
Thanks Biker but not more then 5min before I read your reply, I ordered the monroes, I just wanted to make sure I got the right ones.. When I start the install of the TM leveling kit I wanted to make sure I had the right ones, thanks anyways...
Well I changed my mind on the tires I am going to buy because after looking at Q-tips truck and how his tires look I am preety sure they won me over.. My stock size was 265/60/18 and I am going to get the good years Duratrack in 275/65/18.. I was very limited on a AT tires with the stock size wheel..
