transmission lines?
Old Jan 3, 2010 | 08:13 PM
canadian dakota's Avatar
canadian dakota
Default transmission lines?
has any one out there changed they're trans lines yet and if so what am i in for. i changed my oil today and it looks as though my lines are leaking not bad a few drips on the snow but enough to make the the hose wet thats it
Old Jan 4, 2010 | 11:23 AM
rainier's Avatar
rainier
I need to replace mine as well, in addition to the power steering lines. I've been putting it off though. The leaks aren't dripping or decreasing the fluid much, just making the lines a little wet.
Old Jan 4, 2010 | 12:10 PM
sdsdsd's Avatar
sdsdsd
What pieces of crap these Dakotas are! Who ever heard of transmission lines and power steering lines going bad with a fairly new vehicle. My Buicks and Fords have over 100K with no lines having been replace yet. NEVER DODGE AGAIN FOR ME! Plus the Dealers do not stand behind the product or know how to repair them with out three or four attempts at doing so.
Old Jan 4, 2010 | 12:20 PM
Cuban11182's Avatar
Cuban11182
I can't believe that my power steering lines are starting to rust at 27,000 miles on my 06. I'm a firm believer that this will also be my last mopar product.
Old Jan 4, 2010 | 02:10 PM
Mahadigus's Avatar
Mahadigus
i've done 15+ sets and they never get easier like 1.5hrs is as fast as i can do em.
Old Jan 4, 2010 | 10:09 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Well not bashing on the ladies cause it goes both ways, but have you guys ever heard if it has **** or tires you are gonna have problems?
Old Jan 4, 2010 | 11:05 PM
05Dakotaho's Avatar
05Dakotaho
Aftermarket Tranny and Pwr Strng coolers do the trick. No runs, no drips, no...well you know what I mean.
Old Jan 14, 2010 | 12:16 PM
Slick Dakota's Avatar
Slick Dakota
does anyone know the size of the trans lines are? Cya Slick
Old Jan 14, 2010 | 03:06 PM
dodgetrucker75's Avatar
dodgetrucker75
they are 3/8"
Old Jan 15, 2010 | 01:18 AM
Slick Dakota
The reason why I ask is because back in the day car companies use to put inline trans filters along with the normal trans filters.. The thing is since they did away with it our trans fluid does not get most of the contaminates out of the fluid and then you run into problems.. So for a little investment you can save your self a ton of problems, I am going to do this when I have the dealer pull out all my trans fluid and replace it with Mobil 1.. Cya Slick
