My hunt for boost is over!!!
Old Feb 1, 2010 | 11:23 AM
mprohr's Avatar
mprohr
Don't worry about the slope and the deer. If it's anything like my old Integra, they ramp right over the roof....been there.
Old Feb 1, 2010 | 01:33 PM
Cuban11182's Avatar
Cuban11182
I had a 91 GSX that I paid 2500 for it. Put in 3" stainless downpipe back, KYB adjustable struts, HR lowering springs, ACT clutch, MBC, SAFC II, Walbro 55. It was retarded fast. cracking clear coat, 16 hubcaps from the factory. Total sleeper.
Is yours the AWD
Old Feb 1, 2010 | 03:32 PM
sdtalon's Avatar
sdtalon
Stock turbo will only run 16 lbs or so. Hard pipes and removing the boost restrictor will bump you up a bit. mine has been down for a while now and i miss driving it every day.
Old Feb 1, 2010 | 03:44 PM
mprohr's Avatar
mprohr
Nice toys talon. Thats how it's done in SD. I get a kick out of the exhaust outlet on the Raider.
Old Feb 1, 2010 | 11:22 PM
donkeypunch's Avatar
donkeypunch
King Jackass
Originally Posted by ericemery
Yeah, mines AWD
do they have hard pipe kits?
I plan on doing an FMIC soon.
The car already has a walbro 255 with 12 volt mod. I would like to find an EPROM ecu that I could socket and run dsmlink on.
I think it has a small boost leak, it stumbles a little in 2nd as the turbo spools up. thats my project for my next day off. build a boot leak tester.
Eric! Nice find! I'm not going to lie, it's kind of cool seeing suggestions come to life. LOL! By the way, you don't need an EPROM to run ECMLink V3. They can PROM your non-EPROM ECU to accept the V3 hardware. I'm excited that you got one. You should give me a call sometime.
Here's pictures of my 91 Talon TSi
The List:
2.4L Block and Crank
Eagle Rods, Wiseco pistons, removed balance shafts
Ported and polished head, 5-angle seat cuts, 1mm OS SS valves
Brian Crower 280 camshafts, SI dual valve springs, titanium retainers
Turbonetics T-3 manifold
Garrett 57trim T3/T04E turbo
Dejon Tool 3" intake, Race front-mount intercooler
Tial 38mm wastegate, Tial 50mm blow off valve
FIC 1000cc injectors, Walbro 255 w/ rewire kit, -8 feed line, Aeromotive FPR
DSMLink V3 with speed density
MSD DIS II
JM Fabrications Coil on plug setup w/ 300C coils
KYB AGX struts
3" turboback exhaust
Innovate LC-1 wideband w/ gauge
Autometer: 5" tach, boost gauge, a/f ratio
ACT 2600 w/ 6-puck disc
ACT streetlite flywheel
SS clutch line
SS brake lines
Shepherd clutch pedal assembly
symborski shift kit
Old Feb 1, 2010 | 11:53 PM
donkeypunch
King Jackass
By the way, I just realized something. Did you know that you do not have a 1G Maf? That maf is out of a 2G (better flow and correction than a 1G). If you do not have any form of tuning compensation, I might be a little hesitant. Did it come with a boost controller (adjustable)?
Old Feb 2, 2010 | 09:15 AM
donkeypunch
King Jackass
I will post a picture of my cheap boost leak tester tonight. You can can get (almost) everything at Lowes and Checker (or equivelant)
