No music!
Hey guys whats up it's me again firing another question at you all. I recently had my system totally professionally redone. really nice. then i decided i wanted to run a back up cam (DIY) so i had the head unit off and i happened to touch two red wires together inside the dash behind the head unit and now nothing works. so i checked my fuses under the hood, fuse in the back of the head unit, everything i could think of! I already had the head unit replaced and PAC unit just in case i fried it accidently. anyways im going crazy driving around with no music i can only appreciate my duals for so long. anyone have any ideas what to do?
It sounds like its a fuse, double check em. It looks as if you arent getting power to the radio and such. Some of the fuses may look good but they still maybe bad... maybe even use a test light and see if you are getting power the head unit.
Guest
Posts: n/a
the best way to check a fuse is to do a continuety check with a dmm
some fuses can blow and not be visually noticable.
another thing to check would be both wires to make shure they didnt get hot enough to melt and ground out on something. that would be really bad...
For future reference pulling the battery when you're going to be working on the electronics is a good precautionary step. I agree with the others about checking the fuses with a multimeter, that's a good place to start.
