A strange superchips question
Old Feb 19, 2010 | 09:13 AM
canadiandodge's Avatar
canadiandodge
Originally Posted by rick4dak
What axle ratio do you have ? I have an identical truck to your's with 3.55 gears and there is no way I could even chirp the tires. I don't have a tuner yet.
i have 3.55 and i can still chirp my tires everywhere i go and i have 265 65 18
Old Feb 19, 2010 | 09:59 AM
rengnath's Avatar
rengnath
I cant chirp the tires from a dead stop going straight. I can get the back end to break loose around a dry corner though without getting on it too much.
Maybe after I install the exhaust it will be able to. But right now, she just grips and goes.
Old Feb 19, 2010 | 10:00 AM
rengnath's Avatar
rengnath
Oh, and if I stand on the brakes I can burn the tires off.
Old Feb 19, 2010 | 02:41 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Mine will definitely break em loose from a stand still Before the tuner, the tires wouldnt necessarily break loose but you could hear em catching hell and making a slight bit of noise when the windows were down.
Old Feb 19, 2010 | 02:52 PM
rengnath's Avatar
rengnath
Im not keeping my hopes up, but maybe after I install my exhaust I will be able to. I know its not going to add a ton of power, but Im pretty close to getting them to break loose. On a moist day, the tires skip all the way through 1st gear. Just not enough to lay 2 rows of rubber.
