Transmission issue
Old Mar 8, 2010 | 08:14 PM
Adams95ta's Avatar
Adams95ta
Default Transmission issue
I just had a check engine light checked at autozone and it came back as a
P0846 "TCM has detected a fault in the pressure switch assembly."
and
P0882 "ECM has detected less than 3 volts at the Transmission control relay output circuit, probable cause failed transmission soleniod/ pressure switch assembly."
Anyone had experience with messing with a transmission pressure switch?
Old Mar 8, 2010 | 08:29 PM
Eimer123's Avatar
Eimer123
Mine crapped out on me around 35,000 and dodge replaced it under warranty.
If you have the 7yr 70,000 warranty still in effect I am pretty sure its covered
This is for the 05 Dakota 7yr 70,000
WHAT'S COVERED UNDER
DAIMLER CHRYSLER'S WARRANTIES
Transmission: transmission case and all internal
parts; torque converter; drive/flex plate; transmission
range switch; transmission control module; bell
housing; oil pan; seals and gaskets for listed
components only.
Old Mar 9, 2010 | 10:59 AM
Adams95ta's Avatar
Adams95ta
Thanks for the reply. I don't have that warranty since the truck has been wrecked. Do you know where I could buy the part?
Old Mar 9, 2010 | 06:21 PM
Eimer123's Avatar
Eimer123
Not sure if anyone will carry that part besides Dodge.
Old Mar 9, 2010 | 06:29 PM
Adams95ta's Avatar
Adams95ta
That's what I thought, thanks
Old Mar 9, 2010 | 06:35 PM
Eimer123's Avatar
Eimer123
I guess you can look around at local parts stores, but I am not sure of the exact part# for your truck.
