4wd low ratio?
Old Mar 14, 2010 | 12:51 AM
Eimer123's Avatar
Eimer123
Default 4wd low ratio?
Anyone know what the 4wd low ratio is? 05 Dakota 4.7 4x4.
I am just curious because i was pulling my buddies Jeep liberty out of a ditch and had to go into 4wd low and man it was a torchy little bitch. LOVED IT! pulled him right out!
Old Mar 14, 2010 | 01:00 PM
popsnbeer's Avatar
popsnbeer
I'm not sure, I think it's in your manual though. It also depends on your axle ratio. I think if you multiple your 1st gear transmission ratio X T-case low range ratio X axle ratio, you get what they call a "crawl ratio"
just some info for you! And yes, it will throw your head back in 4 low. I pulled my cousins 2500 cummins 4x4 out of the mud the other weekend. Didn't even shed a tear!
Old Mar 14, 2010 | 03:18 PM
Dinger838's Avatar
Dinger838
when my friend was rebuilding his jeep i saw inside and its like planetary gears hard to explain but really cool.
Old Mar 14, 2010 | 09:13 PM
ND Dakota's Avatar
ND Dakota
Default Here Ya Go!!!!
Low Range Ratio is 2.72, so:
Transmission Gearing With 5-Speed Automatic =
1st. 3.00
2nd. 1.67
3rd. 1.00
4th. 0.75 - Overdrive
5th. 0.67 - More Overdrive
Multiply 2.72 times any of the gearing shown, however, I don't think anybody will be using low range for highway cruising.
Low gear only for tree stumps and such!!!!!!!!!!
