Will a 4.7 HO head bolt onto a non HO block successfully?
Old Mar 30, 2010 | 09:56 PM
AgitatedPancake's Avatar
AgitatedPancake
Default Will a 4.7 HO head bolt onto a non HO block successfully?
Hey guys new to the forum, got a question for ya. I'm in the middle of a huge project swapping an NV3500 in to my '01 grand cherokee, so I have the engine and trans sitting on my garage floor right now.
Anyways this engine is a rebuilt I bought and installed less than 30k ago, and it's been burning some oil recently. Because I have it on the ground I decided now would be the best time to check things out and see whats causing it. Well it's been a hell of a day, but the engine is torn down to the point where I have one head off and the other is just hangin out. We were going to simply replace the valve stem seals but noticed excessive play in atleast the first valve (Haven't pulled more yet) so I'm predicting all the valve guides to be similar.
I've been pricing the machine work to get it all back up to spec, and remanufactured heads, but I was wondering about HO heads? I've read all about the cam upgrade, and I know HO's have different valve springs, but would there be any issue bolting a HO head to a non HO motor and running it with a non HO computer just like you would installing just the cams?
Thanks, AP.
