2008 Dodge Dakota check engine code P2096?
Old Apr 5, 2010 | 04:29 PM
redlinegw's Avatar
redlinegw
Default 2008 Dodge Dakota check engine code P2096?
I just bought a used 2008 Dodge Dakota 4.7 V8 Auto from Cerritos Dodge. My truck has 35k on it and it started shuddering at part throttle then a few days later the check engine light came on. The code is P2096 Downstream fuel trim system 1 lean? The dealer changed an oxygen sensor and it was fine for a few days then the light came back on. Back to the dealer for 2 days and they still dont know what is wrong, so I am taking it to another dealer that is more reputable. Not fun to deal with crap like this 3 weeks after you get a truck Anybody else have this problem? If so how was it fixed?
Thanks,
Old Apr 5, 2010 | 05:50 PM
Eimer123's Avatar
Eimer123
Trouble Code: P2096
Downstream Fuel System 1/2 Lean
Trouble Code Conditions:Engine running in closed loop mode. Ambient/battery temperature above 20F (-7C). Altitude below 8500 feet. Fuel level is more than 15%. If the PCM adds downstream short-term compensation to long-term adaptive, and a certain percentage is exceeded for 2 tr
Possible Causes:
  • Exhaust leak
  • Engine mechanical problem
  • O2 Sensor has failed
  • O2 Sensor signal circuit or return circuit problem
  • Fuel contamination
Old Apr 9, 2010 | 12:03 PM
redlinegw's Avatar
redlinegw
The dealer found the problem to be a small crack in the drivers side catalytic convertor and replaced it under warranty. Whew!
