3rd gen code ?????
hello to everyone out there.i was directed to 3rd gen from the new mem-
bers site. need to decipher a P0001 code that showed on my scanner
hooked up to my 2005 dakota 3.7 auto trans 4x4. does anyone out there
know if that is an actual code # ? scanner is saying it is a fuel volumn
regulator open circuit,????? any ideas? thank you. bilandsam@yahoo.com
can always try and cross reference it with the odometer by shuffling the key from off to on three times it should work I had a low voltage code that came up on the obd reader and the dash so replaced the battery haven't had a problem yet
thanks to both of you.i have a hand held scanner, no chk eng light,purchased wrecked ,precaution before initial road test. truck runs fine.i'll have to check it with the odometer,grear idea. thanks guys.
