combine lift kit 2,5 + 2???
Old Apr 16, 2010 | 06:46 PM
Dakkkota's Avatar
Dakkkota
Default combine lift kit 2,5 + 2???
anybody tried to install both kit at the same time? coil spacer (TM) + rough country strut spacer??? will it work? enough ajustement for camber...yes i know it will add faster waer to CV shafts...
Old Apr 16, 2010 | 08:45 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
Yes, it can be done.
Someone did it on this site a few years ago. They got about 3.5" of lift up front, and they put 3" blocks on the rear. I don't know HOW they got 3" blocks back there because the main brake line going to the rear axle just makes it with 2" blocks when fully extended.
IMO a 2" spacer is terrible on the front end....I can only imagine 3.5" or so.... I don't even know how he got the struts back on the truck to be honest, lol.
Your CV's will get raped on a daily basis, and your tie rods will be in a terrible position, most likely causing steering issues, fast.
My opinion? Think 2" max.
But it has been done successfully.
Old Apr 16, 2010 | 09:16 PM
canadian dakota's Avatar
canadian dakota
if you do this i want updates please from install till the first problem
Old Apr 16, 2010 | 10:12 PM
Altair's Avatar
Altair
Dak attack!
The only person I know of who has done something like this has a 2wd. I would highly recommend rethinking this if you have a 4x4, the angle is too extreme.
Old Apr 16, 2010 | 11:00 PM
hendrixx324's Avatar
hendrixx324
The angle of my tie rods with just a 2 inch spacer scares me... I wouldt add any extra.
Old Apr 17, 2010 | 01:58 AM
projektdirtfab's Avatar
projektdirtfab
ream the knuckle and flip the tie rod....problem solved
Old Apr 17, 2010 | 03:14 AM
canadian dakota
and cv's? really will that work
Old Apr 17, 2010 | 08:20 AM
Dakkkota's Avatar
Dakkkota
Default interesting thread
plz reply!!! CV???
Old Apr 17, 2010 | 08:33 AM
Dakkkota's Avatar
Dakkkota
Default ....
I just went outside and the tie rod is on the top of spindle and the nut facing the ground... to flip it will add angle no?
Old Apr 17, 2010 | 10:39 AM
MonkeyWrench4000
You must be mistaken, the tie rod should be under the lower control arm, with the bolt and nut on top.
I forgot to say, if it's a 4x4, you cannot combine kits, the cv's simply cannot make it, they will pull apart.
In all honesty, 1.5"-2" if the most you can lift the front reliably, and for that, look to the Trail Master leveling kit.
If you have a 2wd you can combine kits, but coming from experience I am telling you your tie rods and rack will be toast fast, as well as your upper ball joint.
Be smart about it. What good is a boat load of suspension lift if it makes your truck weaker and less capable? Nothing cool about that...
