Front Diff Cover
Old Apr 17, 2010 | 09:01 PM
rsofa's Avatar
rsofa
Default Front Diff Cover
2007 DAK whats the secret to getting the front diff cover off 1 bolt will not come out it hits the steering??
Old Apr 18, 2010 | 11:59 AM
bain64's Avatar
bain64
Is the bolt hitting the steering or is it your socket wrench? Try using a standard wrench.
Or try flexing the suspension with a jack. I changed my 06 a few months ago, and the only problem I remember is trying to get the cover back on without messing up the RTV. Practice putting it back on a few times before applying the RTV.
Old Apr 18, 2010 | 12:10 PM
rsofa's Avatar
rsofa
I had the bolt all the way loose by hand and thought I could bring it out with the cover no luck ended up cleaning the best I could and resealing it in place no leaks yet what a pain!!! I used the gray silicone we use at work for oil pan gaskets so it should not leak I hope!!! I was 1 of the bolts on the drivers side..next time I'll just suck the old out and put in the new lesson learned! I don't think flexing the suspension would have helped the center of the diff looks solid mounted to me??
Old Apr 18, 2010 | 12:13 PM
bain64's Avatar
bain64
Yea but at least you got to clean off the magnet on the bottom of the pan this way. I would imagine there is a little more build up at the first fluid change. What oil did you put back in?
Old Apr 18, 2010 | 12:16 PM
rsofa's Avatar
rsofa
I just put the standard Valvoline Syn 80/90 I think in the front and the 80/140 syn with additive in the rear..?
Old Apr 18, 2010 | 01:05 PM
bain64's Avatar
bain64
Just curious, and ensuring you knew the front and rear were different.
