2000 Dakota crew 2Wd I want to lift !!
I have a 00 dakota crew cab 2WD and I would like to lift it. Not to high maybee 2-3 inches or so. Just for more ground clearance. Has anyone done this or have any opinions about it. I was thinking springs in the front and blocks in the rear...
I'm looking at the same thing for an '02. You can go with Fabtech 3", but you'll need new wheels.
The only place I've found so far is www.truckn-store.com. They have 2" coil spacers/adjusters and 2" longer coil springs. I haven't found out whether the coil springs will work for the quad cab yet.
Fabtech makes add-a-leaf kits that will add 1.5" to the rear suspension, pricing is around $55. www.performancelifts.com
Or, since the rear wheel arch is about 2" higher than the front in stock condition, a 2" kit for the front will work without any changes to the rear. Fabtech only recommends going with 30" tires with the 2" lift.
