Diy cai
Old May 20, 2010 | 02:21 PM
blakdak07's Avatar
blakdak07
Default Diy cai
Thought I'd do this to stop hijacking other threads. This is my setup so far.
I showed you mine, now show me yours.
Old May 20, 2010 | 04:01 PM
ND Dakota's Avatar
ND Dakota
Default Hey Ericemery!!!!
I was talking about this just awhile back. Is this on a 4.7?
What size filter did you need to buy?
That sucker should suck some air.
Has to make a difference in performance and maybe even mileage.
What did you do with the original "air sensor" that plugged into the factory box?
Tell me more!!!!!!!!!!
Old May 20, 2010 | 05:03 PM
Moneyman19's Avatar
Moneyman19
well as u can see this is the 4.7, they do make a difference. if u look closely on the right side of the filter he has the air sensor in that small tubing. this isnt a bad idea. im pretty sure u have a scoop Ericemery? so he gets plenty of air. my only problem with it is when it rains and the motor heat. you plan on putting sumthing underneath the filter?
