engine code p0344
can anyone help with this. was going down the highway today and check engine light came on and engine started sputtering when i gave it gas stopped to check things out and seemed to clear up had the codes read at Autozone and got p0344 cam pos sensor. idles ok but if you rev it cuts out around 4000 rpm is this just a bad sensor or a problem with the cam? please help
