what is 4 lock on a 4X4
Old Jun 5, 2010 | 04:40 AM
marcsnyder05's Avatar
marcsnyder05
Default what is 4 lock on a 4X4
I have a 2007 Dakota 4X4 and one of the 4wd settings is 4 lock. What is that?
Old Jun 5, 2010 | 05:21 AM
Cuban11182's Avatar
Cuban11182
4WD Low
Old Jun 5, 2010 | 08:00 AM
Dakkkota's Avatar
Dakkkota
Default no
its 2wd/ 4 lock/ 4wd low/
4 lock is 4wd high
Old Jun 5, 2010 | 08:29 AM
dakotaff's Avatar
dakotaff
Dakkkota is correct, 4Lock is 4wd high.
All 4 wheels are turning at the same speed, DO NOT use 4Lock on dry pavement!
Old Jun 5, 2010 | 09:45 AM
canadian dakota's Avatar
canadian dakota
4 lock is best used on roads with loose condition snow gravel ice (it will not help you stop) it will give you traction to get moving. if you an an average driver to work home mall on the weekends. chances are you will never need to use 4low its a lower gearing to give you more torque to pull you through ie. really steep loose condition hills really deep snow and mud. it'll help keep your tires from spinning keeping traction. the second your tires spin your loosing traction. if your curious find an open field and put er in 4low and give the gas a tap your not gonna go very fast but you'll feel a lot more power
Old Jun 5, 2010 | 04:40 PM
Growlor's Avatar
Growlor
Default I REALLY hate how they renamed 4wd high to lock!
It is really confusing and adds no value IMHO.
The way I have heard it explained is that the "lock" means that the transfer case is locked (as opposed to the vehicles with all wheel drive where it is allowed some slippage to prevent it from damaging itself on normal dry roads.)
Be aware that even though the transfer case is locked you can still end up with only 2 wheels spinning (one front and one rear) if you don't have limited slip or locking differentials.
Old Jun 6, 2010 | 03:58 PM
Dakkkota's Avatar
Dakkkota
what happen inside the diff when switch to 4wd low ou high?
same as rubicon??? magnet?
Old Jun 6, 2010 | 09:46 PM
canadian dakota
im not sure but its prolly not the same as the rubies they have a true locking diff where as we at best have limited slip
