Need trailer hitch (2005 Dak 4.7L V8 RWD)
Old Jul 25, 2010 | 08:36 PM
  #31
superdak05's Avatar
superdak05
they have aftermarket coolers that are a direct bolt on, some even wire tie to the front of the radiator, any shop like pepboys or napa has them
Old Jul 26, 2010 | 01:44 AM
  #32
sleds's Avatar
sleds
I installed a B&M low pressure drop tranny cooler. I bolted it onto the front crossmember and just tied into the return line from the stock cooler that is part of the radiator. Here is a pic or two.
and here is what I am towing with my truck
Old Jul 26, 2010 | 04:31 PM
  #33
saroni's Avatar
saroni
Nice work, sleds. Looks clean! So, it sounds like you avoided using the tie downs that go through the radiator. Do you happen to have a part number for that B&M cooler? I'm guessing that B&M # 70264 is the one? The B&M web site doesn't have a "vehicle lookup" and my car shop prefers I order one and bring it in. Thinking I will order and install myself. Derale also makes a couple (D13504 being the better of the two), but it sounds like B&M is the preferred brand.
Old Jul 27, 2010 | 12:28 AM
  #34
sleds's Avatar
sleds
It's the 70266 supercooler.
Yes, B&M seems to be the choice. I was going to go cheaper when I did mine, but the parts guy told me the B&M is better for colder temperatures (winter) as it doesn't overcool your tranny fluid making it to thick to flow properly.
Old Jul 27, 2010 | 10:51 AM
  #35
popsnbeer's Avatar
popsnbeer
Sleds, which rockwood roo floorplan is that? how big? what made you go with that trailer over other ones?
Old Jul 27, 2010 | 11:02 AM
  #36
saroni's Avatar
saroni
Thanks for the info, sleds. It looks like a lot of the B&M collers are "compatible"; 70255, 70264, 70266, and 70268. Since I'm going from CA to FL, cold weather isn't a concern.
I like how you bolted it to the crossmember and avoided using the ties _ were the bolts the only thing you used, nothing (no padding) between the cooler and the radiator?
Did you need any additional adapters/parts or did everything come with the kit?
