new mags wheels???
Old Jul 21, 2010 | 08:12 PM
damyankee84's Avatar
damyankee84
What is the backspacing on a stock 16" rim?
Old Jul 21, 2010 | 09:24 PM
Dakkkota's Avatar
Dakkkota
16x8 +25
Old Jul 21, 2010 | 09:27 PM
Dakkkota's Avatar
Dakkkota
scuse me back spacing is 5.5''
Old Jul 22, 2010 | 01:54 AM
dodgetrucker75's Avatar
dodgetrucker75
with a 16x8 and a 0 offset you shouldnt have any clearence issues with the 285's and if you have already trimed the plastic, you should really be ok
Old Jul 22, 2010 | 05:03 PM
Dakkkota's Avatar
Dakkkota
what was the offset you tried before?
Old Jul 22, 2010 | 05:18 PM
dodgetrucker75
i havent tried any others except for when i had just the leveling kit on and a 16x8 and not sure of the offset but they were eagle 186 wheels, and i had major fender contact with 265/75/16's
Old Jul 22, 2010 | 06:56 PM
Dakkkota's Avatar
Dakkkota
Default ok
im gonna cross my fingers and order 16x8 0 offset
http://www.mickeythompsontires.com/i...classic_ii.jpg
and forget the ultra wheels 16x8 +10 i hope you are right im afraid to screw up because its not the same wheel widith.
Old Jul 22, 2010 | 08:52 PM
damyankee84
Ok, so if I have the stock 16x8 with a +25 (5.5") offset and switch to a 20x9 with a 0(5") offset. That is moving the tire a 1/2" inboard toward the frame. So if I get any rubbing I could just use a 1/2" spacer to push it back out and it would be back the stock position right?
Old Jul 22, 2010 | 09:21 PM
Dakkkota's Avatar
Dakkkota
Default noooooooooo
dont use wheels spacers truck vibrate as hell in not hub centric
Old Jul 22, 2010 | 10:46 PM
dodgetrucker75
if you need a wheel spacer, use one of these, dont use a plate spacer, they are bad news
