Dumb ABS question
Old Jul 24, 2010 | 08:12 AM
brosh187's Avatar
brosh187
Default Dumb ABS question
So....how do I find out if I have 2 or 4 wheel ABS, so I can get the correct hub assembly for my front left?
Old Jul 24, 2010 | 09:37 AM
rengnath's Avatar
rengnath
It should say on the sticker in the glove box if its rear ABS or 4-wheel ABS
Old Jul 24, 2010 | 11:14 AM
dhvaughan's Avatar
dhvaughan
jack up the truck and remove the front wheel/tire. look closely at how many hoses/wires are attached to the front knuckle area. they'll be at least one hose attached to the caliper which is the brake line. if there is another wire that's attached to a magnet thats stuck into a round hole, generally attached with a little 10mm bolt, then you have front abs.
Old Jul 24, 2010 | 03:54 PM
brosh187's Avatar
brosh187
Well, I tried the simplest 1st, and wouldn't ya know the PO peeled the sticker off. So, when I get a chance, I'll look and see if that wire's there or not. I think I recall the ABS kicking on in the front a while back when I slammed the brakes in the rain...I must have 4 wheel. Thanks for the advice!
Old Jul 24, 2010 | 06:40 PM
popsnbeer's Avatar
popsnbeer
I can't believe nobody recommended the easiest way. Hit the freeway and slam on the brakes! See which ones lock up :-)
Okay, Okay...so maybe there are safer ways to do this :-)
Old Jul 25, 2010 | 01:08 PM
Altair's Avatar
Altair
Dak attack!
You can also request a build sheet from your dealer, they'll need your VIN number and they can give you a printout of your truck's exact configuration from the factory.
