How to get your Daks build sheet.
Finally got mine in. Was missing the spare tire when I bought it though.
Sales Code Description
*C5 Cloth High-Back Bucket Seats
-D5 Med Slate Gray
AGG Sport Group
AJKS Convenience Group
AJPS Power Convenience Group
APAS Monotone Paint
A82P 4.7L Eng (EVA)/5Spd A/T 5-45Rfe(DGQ)
BAZS 136 Amp Alternator
BCES 600 Amp Maintenance Free Battery
BCSS Run Down Protection Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
CABP Bucket Seats
CBZS Prem Vinyl Door Trim w/Map Pocket
CFNS Rear 60/40 Folding Seat
CG3S Advanced Multistage Front Air Bags**
CKES Front Seat Area Carpet
CLES Front & Rear Floor Mats
CSRS Passenger Assist Handles
CSWS Driver Assist Handle
CUCP Floor Console
DGES All 5-Speed Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DHAP Lock-Up Torque Converter
DHTS Elec,Shift-on-the-Fly,P/Time T/Case
DJDS 205MM Front Axle
DMDS 3.55 Rear Axle Ratio
DRBP Corporate 9.25 LD Rear Axle
EVA 4.7L V8 MPI Engine
GACS Tinted Glass Windows
GBBS Tinted Windshield Glass
GCBS Front Door Tinted Glass
GEGS Deep Tint Sunscreen Glass
GJDS Rear Fixed Window
GNAS Rear View Day/Night Mirror
GNDS Driver Side Sun Visor
GNES Passenger Side Sun Visor w/Mirror
GURS Power Mirrors
GXRP Keyless Entry
HAAS Air Conditioning
I28S Route 28 - NS, Buffalo, NY
JAAS Instrument Panel
JA2S Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JKWP 12V Center Console Power Outlet
JPBP Power Locks
JPDP Power Windows, Driver One-Touch
KRSS STRIPE/BADGE/MOLDING/COLOR
K4CP STRIPE/BADGE/MOLDING/COLOR
K8CS STRIPE/BADGE/MOLDING COLOR
LACS Illuminated Entry
LAFS Key in Ign/Seat Belt Warning Buzzer
LAJS Headlamps On Warning Chimes
LALS Low Washer Fluid Warning Signal
LAMS Door Ajar Warning Lamp
LBCS Glove Box Lamp
LCDS Map/Dome Reading Lamps
LHES Rear Dome w/On/Off Switch Lamp
LMBS Halogen Headlamps
LNJS Fog Lamps
LPES Cargo Lamp
LPSS CHMSL Lamp
MBAP Painted Front Bumper
MBDP Argent Rear Bumper
MFDS Bright Grille
MGAS Ram's Head Badge
MHAS Black Windshield Moldings
MUMS Dakota Badge
MUZS SLT Badge
NAS 50 State Emissions
NBKS EVAP Control System
NBQP Federal Tier 2, Bin 10A Emissions
NFBS 22 Gallon Fuel Tank
NHMP Speed Control
NZDS Next Generation Engine Controller
PBJ Atlantic Blue Pearl Coat
QBJS Atlantic Blue Pearl Coat
RCDS 4 Speakers
RDDS Fixed Long Mast Antenna
REFS AM/FM Compact Disc Radio
SBAS Power Rack and Pinion Steering
SCDS Luxury Steering Wheel
SDBS Heavy Duty Suspension
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHCS Front and Rear Stabilizer Bars
SUAP Tilt Steering Column
TBBS Full Size Spare Tire
TBMS Tire Carrier Winch
TXV P265/70R16 OWL All Terrain Tires
TZAP Goodyear Brand Tires
WDQP 16" Steel Spare Wheel
WD1S 16X8.0 Cast Aluminum Wheels
XBSS Pickup Box
XCAS Occupant Classification System
XDXS Scissor Type Jack
XME Under Rail Box Bedliner
XSLS Brake/Park Interlock
XVNP Basic Owner's Manual
YAAS Build To U.S. Mkt. Specifications
YEP Manuf Statement of Origin
YGSA 3 Additional Gallons of Gas
ZAUP Spring - Left Rear
ZCGP Spring - Left Front
ZNUP Spring - Right Rear
ZRFP Spring - Right Front
Z5HS GVW Rating - 6010#
-D5 Med Slate Gray
AGG Sport Group
APAS Monotone Paint
CABP Bucket Seats
CUCP Floor Console
GURS Power Mirrors
GXRP Keyless Entry
JPBP Power Locks
LBCS Glove Box Lamp
LNJS Fog Lamps
LPES Cargo Lamp
LPSS CHMSL Lamp
MFDS Bright Grille
MUMS Dakota Badge
MUZS SLT Badge
NHMP Speed Control
RCDS 4 Speakers
XBSS Pickup Box
finally got mine today too, but didnt find out too much, but on my ram it came back with two strange things, power rack and pinion steering and 3:55 gears, and we all know its not rack and pinion steering, and the gears are 3:73's it has the tags on the diff cover and i checked the gears when i changed the fliud, so something happened but no big deal
lol dodgetrucker I guess it was better for the build sheet to say you had 3.55 and finding out you actually had 3.73's then the build sheet saying you had 3.73 and finding out you actually had 3.55's!
Got mine back. What I thought was intersting was the sheet showed it came with the following: XFUS Trailer Tow w/4-Pin Connector Wiring, but no hitch was listed or installed? That cost me $80 to install. Oh well.
Nice to have the info.
