doors won't unlock when put into park
Old Aug 2, 2010 | 10:20 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
This is right out of the owner's manual
Auto Unlock Feature Programming
Customer Programming sequence to disable or enable:
1. Enter your vehicle and close all doors.
2. Fasten your seat belt (fastening the seat belt will cancel
any chiming that may be confusing during this programming
procedure).
3. Insert the key into the ignition.
4. Within 15 seconds, cycle the key from the OFF position
to the ON position a minimum of four times; ending in
the ON position (do not start the engine)
5. Within 30 seconds, press the driver’s door lock switch
in the UNLOCK direction.
6. A single chime will sound to indicate the feature has
been changed.
7. To reactivate the feature, repeat the above steps.
8. If a chime is not heard, program mode was canceled
before the feature could be changed. If necessary repeat
the above procedure.
Old Aug 3, 2010 | 10:34 AM
WTEBOY703's Avatar
WTEBOY703
now is that pressing and holding or just pressing?
Old Aug 3, 2010 | 12:40 PM
and what exactly does that do?
Old Sep 5, 2011 | 04:22 PM
Elton's Avatar
Elton
Default Programming auto unlock feature
procedure).
been changed.
There is the problem!!!! The 2006 Dakota owner's manual says to cycle the key on and off ending in the "off" position. Sure helps to know the proper steps. Thanks,
Old Sep 5, 2011 | 11:15 PM
durapu's Avatar
durapu
Originally Posted by yttaf
all my doors lock once I hit 15mph, but I manually have to unlock the rear doors even after shutting the truck off! And why did they make it so you can open the front doors even if they are locked?
The reason you can still open the doors when they are locked is in an emergency situation and you need to get out... the rears dont because thats where most people have their children sit and they are more prone to open a door when not necessarry
Old Sep 11, 2011 | 04:19 PM
dakota_raven's Avatar
dakota_raven
Originally Posted by dakota_raven
mine locks the doors at 15mph and when i stop and shut off the truck, i open the driver side door and all the lock open, also when i use the key fob to open the locks it'll open all doors...
Mine too!!
Old Sep 11, 2011 | 06:19 PM
SamuraiDak's Avatar
SamuraiDak
Tried the steps above for the auto unlock and it didn't work.
Old Sep 12, 2011 | 10:08 AM
lghtngblt02
ooops that s a big typo, lol
I had to try it twice before mine took it. Its very picky.
