So this Power Wire....?
Old Aug 3, 2010 | 03:15 AM
Buckmaster's Avatar
Buckmaster
Default So this Power Wire....?
I did a search and pulled up a bunch of threads from back in '08, and just had a few questions to those of you who did it...
Has the Computer learned it.... resulting in a return to stock performance?
If not....
All you do is take the green IAT wire... female/male-wire-resistor-wire-female/male right?
Now exactly what kind of Resistor do I need? I know it was 4.7 something...?
Anything else I should know before I do this and then take a 10 hour drive to Daytona this week?
Old Aug 3, 2010 | 04:46 PM
rengnath's Avatar
rengnath
99 cents for a 5 pack of 4.7k ohm resistors at radio shack. I would send you one of the four extra ones I have from mine ..... but it would probably just be cheaper for you to go buy one. Pick up 2 "female to female" wire connectors and some electrical tape, and youll be set. Then you will just need a wire stripper and some common sense.
Old Aug 3, 2010 | 05:01 PM
ruger226's Avatar
ruger226
What about the air ram power wire is that the same thing?
Old Aug 3, 2010 | 05:12 PM
Cuban11182's Avatar
Cuban11182
Yes but it has the proper plugs for the stock wiring.
Old Aug 3, 2010 | 05:24 PM
Buckmaster's Avatar
Buckmaster
What kindo of Watt do I need? 1/8 1/4 1/2....?
