Dash lights on
Old Aug 11, 2010 | 07:30 AM
motodeficient's Avatar
motodeficient
Default Dash lights on
Started my 05 dakota this morning and my ABS, e-brake, seatbelt, and coolant lights stayed on (seatbelt was buckled and e-brake was not engaged). I drove for a minute, then shut the truck off and started it again. This time only the coolant light stayed on. I tried it again about 10 minutes later, and still just the coolant light is on. I guess it needs coolant, but why would those other lights intially have stayed on??
Also what type of coolant can I add to this truck. I have a couple just of coolant in my shed but I'm not sure if they are compatible.
Old Aug 11, 2010 | 08:55 AM
motodeficient
What kind of coolant can I add to the factory coolant?
Old Aug 11, 2010 | 10:18 AM
I had that happen before, check your battery connections. I had a bad ground that caused all kinds of seemingly unrelated issues. Not sure about the coolant. did you check the owners manual?
Old Aug 11, 2010 | 10:37 AM
dakotaff's Avatar
dakotaff
The manual says:
Mopar Antifreeze/Coolant 5 Year/100,000 Mile Formula HOAT (Hybrid Organic Additive Technology) P/N 5011764AB or equivalent.
Looks like Zerex G-05 will do.
