Brake drum squeal
Old Feb 13, 2011 | 05:11 PM
Originally Posted by bain64
How does braking hard while in reverse adjust them?
thats how the "self adjusting" drum brakes work. Not necessarily "hard" braking, but just back up and applying the brakes. as the pad wears down, more space will form between the shoe and the drum. Each time the car stops while in reverse, the shoe is pulled tight against the drum. When the gap gets big enough, the adjusting lever rocks enough to advance the adjuster gear by one tooth. The adjuster has threads on it, like a bolt, so that it unscrews a little bit when it turns, lengthening to fill in the gap. When the brake shoes wear a little more, the adjuster can advance again, so it always keeps the shoes close to the drum.
