brake performance package
Old Oct 8, 2010 | 05:22 PM
Deer Hunter's Avatar
Deer Hunter
I went with slot & dimple with green stuff, didn't like em. The dimples kept filling with **** and causing gouges in the rotors. The dimples are not self cleaning like the slots are. I went to slotted & cross drilled rotors and Hawk pads. Much better, no issues.
Old Oct 9, 2010 | 07:21 AM
WTEBOY703's Avatar
WTEBOY703
yeah my old front rotors were cross drilled and slotted with EBC Green pads and did just fine. but changed them out when I had 20's on the truck on thought the front breaks where the issue! deffinately was the wheels being warped not the roros at all! whoops oh well always more i can buy!
Old Oct 9, 2010 | 09:14 AM
themoneyshot's Avatar
themoneyshot
i bought some timken wheel bearing from rock auto. anyone else have trouble with the ebc green and dimpled brakes. i have never heard of that but it is good to know before hand.
Old Nov 2, 2010 | 01:36 AM
Nateward's Avatar
Nateward
cross drilled and slotted rotors have less surface area and dont brake as well, I tried them. I also tried ceramic pads and they wore out really fast so I will go back to semi metalic
Old Nov 2, 2010 | 07:38 AM
bain64's Avatar
bain64
So how much shorter can you stop with your standard pads Nate? Sounds like you did testing, how many feet difference?
Hmm... Perhaps there is validity to your statement, at least until we consider braking under extreme conditions like 75-0 or going down a mountain pass. While your pedal still feels stiff, what your brake pads feel is FAAAADE.
Old Nov 2, 2010 | 11:13 AM
superdak05's Avatar
superdak05
i went with the standard napa upgrade, brakes and rotors, dont do towing just racing, so stop fast or hard is not an issue
Old Nov 2, 2010 | 11:45 AM
I've done oreilly's standard stuff for years and never had a problem. Sure, it's neat to say "I've got slotted/crossdrilled/dimpled, etc rotors and "performance" pads, but for normal everyday driving is one really that much better than the other to justify the cost difference?
Old Nov 2, 2010 | 10:47 PM
gjmoran's Avatar
gjmoran
my brakes squeak like hell and i took it back in to the dealership to have them serviced and all they said was 'you have over 30% of brake pad left, they are fine' the squeaking drives me insane
Old Nov 2, 2010 | 10:58 PM
mine dont make a bit of noise. you might want to buy some of that caliper grease and grease the slide pins and put some rtv on the back of the pads. squealing is basically a high frequency vibration, so if you rtv the pads to the calipers it eliminates the vibrations.Now, before anyone says how dumb that idea is, it works for me and has for years.....lol
