New tires, level kit install
Old Oct 23, 2010 | 07:07 PM
Colinskee's Avatar
Colinskee
Default New tires, level kit install
i just ordered the 2 inch daystar leveling kit and a set of 265 75 16 bfg km2's. if anyone ran into any little quirks while installing the daystar kit any advice would be great. i will post some picks during the install thanks
Old Oct 23, 2010 | 09:09 PM
brbcbrent's Avatar
brbcbrent
Install was pretty straight forward, there's a lot of good write-ups on the forum already...the only snag I ran into was the lower strut mount bolt was seized in the bushing I ended up cutting it off before I discovered that it's a special order dealer part. I made do by using a grade 8 bolt for the week it took to get the proper bolt in. Other than that no issues!
Old Oct 23, 2010 | 09:24 PM
WTEBOY703's Avatar
WTEBOY703
uhm...idk i'm lowering the rear yay
Old Oct 24, 2010 | 03:51 AM
nicholas9393's Avatar
nicholas9393
sway bar end links will probably break, the top nut on the strut will probably be seized up
Old Oct 24, 2010 | 04:31 PM
Dakkkota's Avatar
Dakkkota
Default nick X2 absolutely right
have a second set of hands to pry down the lower comtrol arms...and if you lift the rear look at the stock shock if there is still rebound at the end of travel....and i HIGHLY SUGGEST YOU TO SWAP STOCK FRONT SHOCKS! monroe of ranchos while ther are in your face.
Old Oct 24, 2010 | 08:25 PM
MonkeyWrench4000's Avatar
MonkeyWrench4000
I suggest you remove the sway bar end links from the nut under the lower control arm, and swing the sway bar out of the way with the end links still attached to it.
As said earlier, the end links tend to snap if trying to remove the nut on top. So, remove the nuts on the bottom of the link, under the control arm, and they wont break.
Old Oct 25, 2010 | 02:11 AM
WTEBOY703's Avatar
WTEBOY703
yeah what they said! lol
