Old Aug 6, 2015, 07:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical System
Print Wikipost
coil or sparkplug problem
Old Dec 1, 2010 | 11:20 AM
  #21
WTEBOY703's Avatar
WTEBOY703
yeah...and with the Autolites you bought i know mine came with new rings on the plugs as well...did yours? and glad everything is cleared up and running right! put in certain things you'll feel the truck run smoother and better! so yeah glad you took away from our experiences and knowledge and came out on top and love it!
Old Dec 1, 2010 | 11:34 AM
  #22
Six_Shooter's Avatar
Six_Shooter
Originally Posted by VConfreda
Im not shure what im gonna be doin with them, I onily replaced 5 of them tho cuz one of my coils broke last week and needed to be replaced.
Well, let me know what you decide.
Old Dec 2, 2010 | 08:02 AM
  #23
nanohead's Avatar
nanohead
I have the same problem on my 4.7 05.... Its throwing code about intermittent miss on #1 cylinder.. I changed the coil AND plug and its still happening...
Guess I have to go deeper into the ignition system, I have the autolites, and I too feel no difference.
Old Dec 2, 2010 | 09:27 AM
  #24
WTEBOY703's Avatar
WTEBOY703
NANOHEAD...hmmm check the gaping! and make sure everything is seated correctly and connected properly and that the coil itself is actually locked into the clip!
Old Dec 2, 2010 | 10:25 AM
  #25
rengnath's Avatar
rengnath
It could be the injector as well.
Old Jan 16, 2012 | 10:21 PM
  #26
Joe Perez's Avatar
Joe Perez
Default Dodge Dakota COP problem
The connector to my coil broke so I spliced the wires and connected them direct worked fine. Ordered the connector and when I put it all together im now not getting any fire. I use a multi meter to test wires and theres fire, but when i plug it into coil theres no fire. I plug the coil into another connector and it works just fine. Again wire has fire but when i plug it into coil the wire goes dead... Pleas help thanks
Old Jan 17, 2012 | 05:29 AM
  #27
erau's Avatar
erau
Sounds like the connector is getting juice but not enough to energize the coil completely to produce a spark.
What method did you use to attach the connector? Did you solder it?
