Reset Speed and tach
Old Jan 21, 2011 | 09:49 PM
zampolit's Avatar
zampolit
Default Reset Speed and tach
I have an 05 dak, and made an apparently very dumb mistake. The temp gauge was stuck at normal all the time so I decided to take apart the cluster, and fix the gauge needle. I got the needle fixed, but after putting everything together I noticed that the speedometer and tach are way off. at about 5 mph the speed says 52 mph and never goes lower.
All in all, I searched around and didn't see anything, so I was wondering if anyone had any ideas about a way to reset the needles to Zero at startup so they are calibrated again.
Thanks
Old Jan 21, 2011 | 11:47 PM
Jaded's Avatar
Jaded
Man, I had this happen when I put some new gauge faces in my old ram. Now I can't remember the fix. Maybe do a search on nu-image install or something.
Old Jan 22, 2011 | 01:03 AM
marcsnyder05's Avatar
marcsnyder05
Have you tried taking off the negative cable on you battery
Old Jan 22, 2011 | 01:10 AM
rengnath's Avatar
rengnath
Yeah, I would try resetting the PCM.
Are the needles going to the resting position when you take the key out of the ignition?
Old Jan 22, 2011 | 01:18 AM
zampolit's Avatar
zampolit
yeah, I already tried everything I could think of to calibrate them. I unplugged the negative battery terminal overnight, and I even tried taking all the needles off and plugging it in so they would zero out, then putting the needles back on...... (didn't work) I think I might just have to try to get the dealer to plug in their magic little computers to reset the cluster tomorrow. Thanks for the comments so far, this really is a helpful forum.
Old Jan 22, 2011 | 07:16 AM
Eimer123's Avatar
Eimer123
not sure if this works for our truck, but this is instructions for a caravan cluster
DIAGNOSIS AND TESTING - SELF-DIAGNOSTICS
The instrument clusters are equipped with a self diagnostic test feature to help identify electronic problems. Prior to any test, perform the Self-Diagnostic Test. The self diagnostic system displays instrument cluster stored fault codes in the odometer display, sweeps the gauges to the calibration points, and bulb checks the warning indicators. When the key is in the ON position with the engine not running, the MIL will remain illuminated for regulatory purposes.
To activate the Self-Diagnostic program:
With the ignition switch in the OFF position, depress the TRIP ODOMETER RESET button.
Continue to hold the TRIP ODOMETER RESET button until Sof and a number (software version number (i.e. Sof 3.2) appears in the odometer window then release the button. If a fault code is present, the cluster will display it in the odometer display. When all fault codes have been displayed, the cluster will display “end” in the odometer display. Refer to the INSTRUMENT CLUSTER DTC'S table to determine what each trouble code means. INSTRUMENT CLUSTER DTC'S DTC DESCRIPTION
100.0 LOOP-BACK FAILURE
100.1 ABS COMMUNICATION FAULT
100.2 BCM COMMUNICATION FAULT
100.3 EATX COMMUNICATION FAULT
100.4 FCM COMMUNICATION FAULT
100.5 ORC COMMUNICATION FAULT
100.6 SBEC/DEC/MCM COMMUNICATION FAULT
200.0 AIRBAG LED SHORT
200.1 AIRBAG LED OPEN
200.2 ABS LED SHORT
200.3 ABS LED OPEN
200.6 EL INVERTER TIME-OUT
200.7 EATX MISMATCH
CALIBRATION TEST
The CLUSTER CALIBRATION table contains the proper calibration points for each gauge. If the gauge pointers are not calibrated, a problem exists in the cluster. If any gauge is out of calibration, replace the cluster.
CLUSTER CALIBRATION SPEEDOMETER CALIBRATION POINT
1 0 MPH (0 KM/H)
2 20 MPH (40 KM/H)
3 60 MPH (100 KM/H)
4 100 MPH (160 KM/H)
TACHOMETER
1 0 RPM
2 1000 RPM
3 3000 RPM
4 6000 RPM
FUEL GAUGE
1 EMPTY
2 1/4 FILLED
3 1/2 FILLED
4 FULL
TEMPERATURE GAUGE
1 COLD
2 1/4
3 3/4
4 HOT
ODOMETER SEGMENT TEST
If a segment in the odometer does not illuminate normally, a problem exists in the display.
ELECTRONIC TRANSMISSION RANGE INDICATOR SEGMENT TEST
If a segment in the transmission range indicator does not illuminate normally, a problem exists in the display.
Old Jan 22, 2011 | 07:18 AM
Eimer123's Avatar
Eimer123
Copy/paste from another forum:
  1. Begin the test with the ignition switch in the Off position.
  2. Depress the odometer/trip odometer switch button.
  3. While still holding the odometer/trip odometer switch button depressed, turn the ignition switch to the On position, but do not start the engine.
  4. Release the odometer/trip odometer switch button.
  5. The instrument cluster will simultaneously begin to illuminate all of the operational segments in both VFD units, and perform a bulb check of each operational LED indicator. The VFD segments and LED indicators remain illuminated as each gauge needle is swept to several calibration points and back. If a VFD segment or an LED indicator fails to illuminate, or if a gauge needle fails to sweep through the calibration points and back during this test, the instrument cluster must be replaced.
  6. The actuator test is now completed. The instrument cluster will automatically exit the self-diagnostic mode and return to normal operation at the completion of the test. The actuator test will be aborted if the ignition switch is turned to the Off position, or if a vehicle speed message indicating that the vehicle is moving is received from the PCM over the CAN data bus during the test.
