"Creaking" Steering Wheel
Old Feb 5, 2011 | 09:37 AM
ND Dakota's Avatar
ND Dakota
Default "Creaking" Steering Wheel
When I turn my steering wheel it creaks and groans like an old rocking chair.
I thought it could be the cold weather but even with the cab warmed up it still creaks.
What's with this???
Annoying as hell.
Old Feb 5, 2011 | 10:30 AM
mine groans sometimes....fluid is good and level is ok, i just live with it....maybe the rack is going cause it does not sound like it's coming from the pump area.
Old Feb 5, 2011 | 01:02 PM
zampolit's Avatar
zampolit
Mine was creaking right behind the steering wheel itself. If that is what yours is doing, I fixed it by taking the plastic off the ignition area between the wheel and the dash and spraying a little silicon spray in the shaft and turned the wheel a few times until it somewhat stopped. I couldn't get rid of it completely, but it's almost gone.
Old Feb 5, 2011 | 02:35 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
There was a TSB out for the midshaft replacement or greasing or something IIRC. Hit the search button up. A couple members experienced the same thing you guys are. It was for the earlier Daks.
