Thermostat Install DIY
Old Feb 6, 2011 | 04:18 PM
Eimer123's Avatar
Eimer123
Well just got home from a day of driving. Things I have noticed. Pretty much no difference. Heater still blows just as hot. The engine seams to run better, but I also changed spark plugs from 5224, hard to tell if there is more power because the roads are still really slick.
I used a dremel to make the notch, but a small hand file would work. The notch does not really need to be perfect, just enough to clear the o-ring notch.
Originally Posted by Dakkkota
what about a 160 degree? will the computer run fine?
I have not heard anything about the 160, but 180 would be as cold as I would go on a my truck. 160 seams way to low, if the engine had a carburetor you might get away with it.
Old Feb 6, 2011 | 04:19 PM
rengnath's Avatar
rengnath
What spark plug/heat range did you change from and to?
Old Feb 6, 2011 | 04:20 PM
thunder98110's Avatar
thunder98110
well just got one at napa. not sure when ill install it. thanks though.
i heard bad things about 160's in 2gens, throws to many codes.
Old Feb 6, 2011 | 04:31 PM
Eimer123's Avatar
Eimer123
I went from Autolite 5224 - Heat range D11
to Autolite 3923 or 3922 I don't recall - Heat range - D11
I hope they are 3922 the same that the HO engine runs. Something tells me I put the 3923 from the 3.7. Crap I know I should have double checked that. All I know it that I do not like them. I will know on Monday when I get to work. If they are the 3923 I will change them out to the 3922 and see if they are any better. If not I will go back to the 5224
5224, 3923 and 3922 are all the same heat range according to the web site.
Old Feb 6, 2011 | 04:36 PM
rengnath's Avatar
rengnath
3923s are one range colder than stock (everyone says), I run the same heat range except they are NGK 4644s.
Old Feb 6, 2011 | 05:56 PM
Dakkkota's Avatar
Dakkkota
what it that water pump??? what is different than stock??
Old Feb 6, 2011 | 06:42 PM
Fitz-C's Avatar
Fitz-C
i usually run 195 in the winter 180 in the summer.
with the 195 when temps dip down into the -30's - 40's (god bless edmonton) i usually read about 182-190.
with the 180 in the summer i usually read about 179 -189 (up to 200 with ac on)
Old Feb 6, 2011 | 08:06 PM
So.....bottom line. What will this mod do? Is it another power wire or does this give some benefit?
Old Feb 6, 2011 | 08:18 PM
Dakkkota's Avatar
Dakkkota
with my custom tune in my 1989 gta and 2003 sliverado i installed a 160 degree so with the custom tune i can add some advance to timming without pinking and gain some hp....
Old Feb 6, 2011 | 10:36 PM
Eimer123's Avatar
Eimer123
The water pump is nothing special that I can tell, the propeller looks almost the same as stock. The reason for my change was the bearing was going.
Cooler engine to an extend is a happier engine. Every 10 degrees you drop the engine temp is good for 1HP, So nothing major
