Blower motor pig tail/ resistor issues
Old Feb 7, 2011 | 04:42 PM
ketco5's Avatar
ketco5
Default Blower motor pig tail/ resistor issues
When i first bought my truck my blower motor stoped working. The dealership repaced the resistor and it was fine. After a while i lost two of the four speeds but i really didnt mind it . Last summer it would just stop blowing all together. I replaced the pigtail and resistor and things were fine. It has now AGAIN things have gone down hill. When you look inside the pigtail you can see a definite burn/ melted mark in the center of the plug. Any ideas what would cause this? I dont feel like replacing this thing every 4 months. the resitor seems to be working fine since i replaced that and it is still doing the same thing.
Old Feb 8, 2011 | 09:08 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Something isnt connected fully... sounds like a loose connection building heat...
Old Feb 9, 2011 | 01:57 AM
Fitz-C's Avatar
Fitz-C
if you have any "B" codes. The control unit may be no good...
theres not much in that circuit to go bad, goes from junction box to a/c heater control, to blower resistance control
if you sure its not a loose harness or dirty contacts in resistor plug, then i would look at the control unit
Old Feb 9, 2011 | 12:04 PM
ketco5's Avatar
ketco5
thanks guys ill give it a shot
