Weird Rattle from the drivers side wheel well
Old Feb 24, 2011 | 06:58 AM
eaglescanfly's Avatar
eaglescanfly
Default Weird Rattle from the drivers side wheel well
Hey all I know this is in another thread but wanted to separate it do to me having some videos of the metal on metal or loose rod sound. I still can't find what is causing the noise.
Part 1 is me coming to a stop with the brakes applied.
http://www.youtube.com/watch?v=1_r3q9WQAxY
Part 2 is me going around a couple of bends.
http://www.youtube.com/watch?v=gVjdSyu-MeA
I know some of you responded on the other thread but decided to separate it do to people not knowing there is a recorded audio of mine.
Old Feb 24, 2011 | 11:53 AM
dakota_raven's Avatar
dakota_raven
I can't hear the audio clip (i'm at work) but i'll suggest that you check the sway bar links.
Good luck!!!!
Old Feb 24, 2011 | 12:04 PM
hendrixx324's Avatar
hendrixx324
It sounds like tie rods or sway bar end links.
Old Feb 24, 2011 | 04:10 PM
Backwoods18's Avatar
Backwoods18
Eric is right, however mine made noise and didn't have any movement in any direction. I have since removed my sway bar and end links and the noise vanished.
Old Mar 1, 2011 | 09:27 PM
eaglescanfly
Hey guys,
thanks for the replies. To let you all know I had the sway bar links replaced recently so thanks to all you guys i got under there and actually found it. Tight fit tho lol....
I got under my truck with it on the ground and turned the wheels to the right a bit and then turned the truck off for a stiff steering column and guess what the noise is coming from where both the inner tie rod ends connect to the rack and pinion. Now the next challenge is to get the mechanics to see it.
Old Mar 8, 2011 | 11:00 PM
eaglescanfly
Hey got the new rack installed and guess what apparently I had more than 1 problem. And well the loose steering is fixed and that stupid rattle is more noticable? Have any ideas?
