brake question
Old Mar 24, 2011 | 12:41 PM
Dinger838's Avatar
Dinger838
Default brake question
I'm ordering new pads and rotors today from brakeperformance and was wondering if there's a big difference between their best the slotted and dimpled vs the cross drilled and slotted. Also is It worth the extra for the best pads? I tow alot And have big mud tires and need the best stopping power I can get!
Old Mar 24, 2011 | 03:12 PM
marcsnyder05's Avatar
marcsnyder05
I got the dimpled and slotted rotors and the semi-metallic pads. I like them they are a good bit better than stock. I've had them for about 3 weeks
Old Mar 24, 2011 | 03:47 PM
Dinger838's Avatar
Dinger838
I'm going With dimpled And semi metallic thanks guys
Old Mar 24, 2011 | 03:50 PM
stay away from cross drilled. they will crack.
Old Mar 24, 2011 | 07:47 PM
Dinger838's Avatar
Dinger838
Okay. Thank You I Just wanted to make sure these were an improvement over stock before I Buy
Old Mar 24, 2011 | 10:14 PM
Dinger838's Avatar
Dinger838
is the slotted rotor decent or should i spend the extra for slotted dimpled.... ahh too many choices.
Old Mar 24, 2011 | 10:44 PM
imo it's more about the pads than the rotor. Nothing wrong with the factory rotors for me, just get a good set of ceramic pads.
Old Mar 24, 2011 | 10:54 PM
Dinger838's Avatar
Dinger838
i've warped two sets of them, and i do not ride the brakes is all. I'm almost always towing or have a full bed. im thinking slotted roters and ceramic pads
Old Mar 24, 2011 | 10:59 PM
most def ceramic. they dont clog up the slots/dimples.
