throttle body spacer
Old Apr 19, 2011 | 08:18 AM
Dakkkota's Avatar
Dakkkota
Default throttle body spacer
does it help in townig application??? it is supposed to help the low end torke
Old Apr 19, 2011 | 08:37 AM
damyankee84's Avatar
damyankee84
Dont waste your money. They are only good on engines with a carb.
Old Apr 19, 2011 | 09:32 AM
rengnath's Avatar
rengnath
You could by one and use it to inject nitrous into the intake
Old Apr 22, 2011 | 11:26 AM
kwanczyk's Avatar
kwanczyk
with mine i can tell a little bit like you said with torque. you can feel it off the light. for $50 not bad in my opinion, and you get the whistle noise too
Old Apr 22, 2011 | 11:36 AM
donkeypunch's Avatar
donkeypunch
King Jackass
F'ing useless. Pay $50 for an intake or e-fan. You will be happier.
In my humble racing experience, I have never seen a throttle body spacer on a race car. Carb'd vehicles are different...they are not fuel injected. They can use all the atomization they can get.
Old Apr 22, 2011 | 12:07 PM
gjmoran's Avatar
gjmoran
i want to do the efan conversion but im scurred! its my daily driver and i dont want to mess anything up :/
Old Apr 22, 2011 | 12:41 PM
rengnath's Avatar
rengnath
Im doing my efan conversion in July. I plan on wiring the controller first, and once I am positive it is functioning 100%, Ill put the fan in. Alot of guys put the fan in, and then they cant figure out the wiring so they are screwed. So I suggest you get the controller wired up first, and run the clutch fan as long as you have to.
