"power wire" idea
Old May 1, 2011 | 11:49 PM
wingman_214's Avatar
wingman_214
Default "power wire" idea
I have a power wire I purchased from another member here at df. The wire works by tricking the ecm into thinking that the air charge is ~20° cooler and therefore adds a little more fuel. But that shouldnt really work because leaning the fuel mixture nets more hp but its more dangerous because of detonation and combustion temps could melt a piston.
My question is if i wire the resistor between the two ait sensor wires would the ecm read 20° warmer and lean out the mixture accordingly to net a gain in hp? Does anybody have a tuner that can read live sensor data and some time to test if my theory?
Old May 4, 2011 | 12:07 PM
reagor's Avatar
reagor
not likely...adding resistance will lower the voltage (voltage drop)
to raise you would need alot more electronics
quick thinking probabily not accurate
get a 12v to 5v adapter(CEL PHONE CHARGER?)...and then add a adjustable resister to drop the 5v to .2v or something like that and add it to the return wire
this could fry all kinds of stuff and i am no electrical engineer
if i were to research this mod i would buy a new air temp sensor... supply it with 5v and read the return voltage
i would record the return voltage at stepped intervals between say 32F and 120F every 5F ...do this with the sensor in a plastic bag in a hot water bath with a high accuracy digital thermometer
also at the step points also measure the resistance across the sensor
now graph the data and see what the diff is for both plots for a 20F increase/decrease
this might get you somewhere in the ball park of your plan
Old May 4, 2011 | 12:54 PM
wingman_214
Ive got a resistor box, just have to drive 6.5 hrs to get it. I only say leaning the mixture will gain power because oems tend to run "safely rich" at ~12.5 to 13 to prevent detonation.
Old May 4, 2011 | 01:00 PM
reagor's Avatar
reagor
resistor box?
Old May 4, 2011 | 01:33 PM
wingman_214
Its a small box that you hook up in line with what ever sensor you want to mess with. Then its got dial you adjust.
http://www.google.com/m/products/det...80807898334794
Old May 4, 2011 | 02:28 PM
also called a decade box for us old school electronics technicians...lol
