Driver side window not working. Help!!
Old May 12, 2011 | 08:00 AM
Backwoods18's Avatar
Backwoods18
Well I don't know what happened. I went out to the truck to work on it. Turn the key on and nothing. Window wouldn't go down. Passenger and locks work but the relay for the driver's side doesn't make noise. Start the truck and the window goes down. I went up and down with it a few times. Shut the truck off and turn the key on and it doesn't work. ????? Idk what the heck is going on but as long as it goes down when the truck is running I will live with it until it doesn't work at all.
Old May 12, 2011 | 04:13 PM
superdak05's Avatar
superdak05
sounds like a grounding issue, my motor assem. went, 55.00 for the part from dodge, simple swap, just make sure the window is lined up correctly before tighting, or you will hear wind
Old May 12, 2011 | 05:11 PM
Backwoods18
I will keep that in mind. Thanks.
