Exhaust with Injectors
Old Jul 7, 2011 | 12:26 PM
ruger226's Avatar
ruger226
Kent i say go for it so you can tell me if its worth it or not. Haha
Old Jul 7, 2011 | 01:01 PM
wingman_214's Avatar
wingman_214
Were you reaching the limit of your fuel Injectors? Seems odd to change the injectors otherwise considering their both siemens/bosch ev6 with 4 holes.
Old Jul 7, 2011 | 01:54 PM
gjmoran's Avatar
gjmoran
what do the injectors do? more throttle response?
Old Jul 7, 2011 | 03:43 PM
Backwoods18's Avatar
Backwoods18
More fuel. Which if you have a free flowing exhaust and a CAI = more power so to say...
Old Jul 7, 2011 | 04:07 PM
thunder98110's Avatar
thunder98110
more fuel means less power in this application, motor cant burn it all so you end up running rich/unburnt fuel. unless you have boost. thats the way hemifever explained it to me. one of my early tunes was way to rich, 11aft at wot. was sluggish. the difference between 11 and 13.2 is huge. but i know billy needs a richer afr b.c of boost.
Old Jul 7, 2011 | 04:18 PM
rengnath's Avatar
rengnath
Theres no way to add more fuel by just swapping injectors without running in to problems. By just adding more fuel, the AFR will be read by the 02 sensors as rich, and the PCM will try and lean it out. If it can lean in out enough, youll get an engine light. You need to change the fuel maps if you want to be able to run a richer mixture. HOWEVER, you can get achieve more power and better throttle response by getting an injector that sprays/distributes the fuel better through the cylinder to achieve maximum burning.
Old Jul 7, 2011 | 04:26 PM
Backwoods18
This explains it. I achieved more throttle response and a little more "zip".
Old Jul 7, 2011 | 04:44 PM
rengnath's Avatar
rengnath
Thats no suprise at all. Especially if your truck has higher miles, swapping out the injectors should just help. If you get an overall better injector, you should see a noticable difference.
Old Jul 7, 2011 | 04:56 PM
wingman_214
Both injectors are ev6 4 hole so they will have the same spray pattern. The difference is because the 4.6l injectors flow more the is no momentary lean condition after you mash on the gass and the pulse width is smaller so fuel delivery should be more exact when compared to timing.
Old Jul 7, 2011 | 06:35 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
So its worth it even of you aren't boosting? The 4.6 is just a better overall injector with quicker response than our stock ones. Not a waste of gas just a quicker throttle response so instantaneous power rather than delayed power? Hopefully the mod burns the same amount of fuel..
