06 Dakota quad lighting problem...help please!
Old Aug 25, 2011 | 09:24 PM
sayreman's Avatar
sayreman
Default 06 Dakota quad lighting problem...help please!
Just bought a 2006 dakota. Realized when I got home I had a tailight out. Then I realized my yellow marker light on the front was out too. Went and bougt new bulbs but lights still don't work. Turn signals, hazards and brake lights all work (same bulb). What's happening?
Old Aug 26, 2011 | 06:49 AM
Backwoods18's Avatar
Backwoods18
Welcome to the forum! Did you check to see if it was a fuse? The fuse block is under the hood on the drivers side by the fire wall and has a diagram of each fuse on the inside cover. Hope this helps
Old Aug 26, 2011 | 10:11 AM
If you just bought it, take it back and tell them to fix it (assuming you bought it from a dealer). At least here in NC (and other states I have lived in), car dealers are required to do an inspection when they sell a vehicle.
Old Aug 26, 2011 | 02:14 PM
DodgeCares's Avatar
DodgeCares
If the fuse doesn't do the trick send me your VIN and I will check for TSB's and recalls. I know there was recall # F08 for the Cab Compartment Node (CCN) control module on some of these vehicles that showed symptoms of lights not working intermittently.
Old Aug 26, 2011 | 05:10 PM
and if the truck is out of warranty, you gotta pay for it out of pocket. Control modules are e-x-p-e-n-s-i-v-e!
