question about strut replacement
Old Sep 11, 2011 | 04:00 PM
ballsout's Avatar
ballsout
Default question about strut replacement
im dumb and i have tried to search for a post for DIY strut replacement for my dakota on here but havent found anything.
questions are: do i need to remove the springs? is there any tips the guys who have already done their struts can give me? I am going to be doing all 4 this week cuz i want to be able to drive something that feels like a truck and not like my ski boat on the highway.
thanks a lot.
oh yea and any special tools i should get that will make my life easier?
Old Sep 11, 2011 | 04:10 PM
Cuban11182's Avatar
Cuban11182
Your best bet is to remove the strut assemblies and take them somewhere where they have a wall mounted strut compressor. It is a bitch to try and do it with normal spring compressors. I ended up taking them out and having the local tire kingdom complete it.
Normal tools will be alright. I had to take off the top ball joint out of the knuckle to make the removal of the strut alot easier.
Old Sep 11, 2011 | 05:27 PM
ballsout's Avatar
ballsout
so i do have to remove the springs? i looked at the service manual and it says that i can leave the springs in place.
if it makes a difference im 2wd.
Old Sep 11, 2011 | 05:36 PM
Struts require a coil spring compressor to replace. Yes, the springs must come off.
Old Sep 11, 2011 | 06:36 PM
Cuban11182's Avatar
Cuban11182
Like Jkeaton said, it's a strut assembly and them come out as one piece. When you look at the replacement shocks you will see there is a long stud out of the top that holds the whole assembly together.
Old Sep 11, 2011 | 09:58 PM
JimBio's Avatar
JimBio
You can rent the tool at the parts store, it's not that bad. I did my old Neon struts and the neighbor brought over his older Lexus and we did those too. Just be carefull, it's a tooth buster if you fail.
Old Sep 11, 2011 | 10:30 PM
marcsnyder05's Avatar
marcsnyder05
I did my struts yesterday with a normal spring compressor it wasn't too bad.
