Dak dudes quick question
Old Sep 17, 2011 | 06:25 AM
Obiejuankinobie's Avatar
Obiejuankinobie
Default Dak dudes quick question
Changing brake pads on my wifes 2006 4x4 Dakota. I did the front know it's time for the back. Are the back pads same as front or different part number.
Thanx in advance.
Old Sep 17, 2011 | 07:09 AM
dakotaff's Avatar
dakotaff
The rear brakes are drum. Very different!
Old Sep 17, 2011 | 10:54 AM
yep, you wont find pads on the rear brakes, only shoes. Go to Rock Auto if you want them cheap, otherwise advance, auto zone, oreillys or something like that. I see several part numbers, you will have to find out which ones you need. I dont know if they made a design change mid-year or something because I see it asking if it has two return springs or one.
Last edited by jkeaton; Sep 17, 2011 at 12:09 PM. Reason: forgot something and corrected spelling
Old Sep 17, 2011 | 11:08 AM
wingman_214's Avatar
wingman_214
05-07 list pab853 with one upper return spring.
06-+ list pab923 with 2 upper return springs.
Thee differance seems to be the manufacture date. Before 10-17-05 only one upper spring was used and after 2 rerurn springs were used.
