Already thinking about xmas...
Old Sep 26, 2011 | 04:48 PM
chambers's Avatar
chambers
Originally Posted by thunder98110
just get the same # but they will be 4 pin vs 2. better spray pattern. with higher # then you will need custom tuning or you will be running stupid rich.
I was wondering why people were talking about swapping injectors, b/c the stock one's can put out plenty of gas to deal w/ bolt on's and the pcm can adjust quite a bit to keep you from running lean. Thanks for the explanation.
Ozone you could do the underdrive pulley I've had an ASP on my truck for over a year w/ no issues. The ati superdamper would be the best choice but costs a bit more, asp did have issues w/ them when they first made them, but that has long since been resolved. I'm not sure how much the injectors will help you w/ the better spray pattern that thunder mentioned, but if you do them I'd like to see your track times before and after. How many #'s are the stock 3.7 injectors? Looked on airram's site and found these http://www.airram.com/product.php?ca...productid=1353. I did a fastman ported TB and it helped throttle response and seemed to give some more grunt. Jba has headers for the 3.7, but I'm not sure if they will fit a dakota.
Old Sep 26, 2011 | 05:04 PM
Originally Posted by jkeaton
I'm getting me a set today!
impulse buying gone bad...lol
Old Sep 26, 2011 | 06:36 PM
cheeseburger's Avatar
cheeseburger
Can't give up my trans tuning
You could always just get a getrag 238 programmer. it's soo simple. It gives you a big metal pole in the floor with which to adjust you shift points manually.. it's awesome.
Old Sep 26, 2011 | 07:15 PM
might as well buy a whole new truck....dropped about $1200 into her this past month...dont need to go dropping another $500 for the SCT. I'll just hang on to the injectors for the next round of engine mods....
Old Sep 26, 2011 | 07:17 PM
cheeseburger
valid point...
Old Sep 26, 2011 | 07:30 PM
MitsuRaider's Avatar
MitsuRaider
Im running 39 injectors, and i can tell u that u will definitely need a custom tune. I mean u will literary smell the gas as u drive around
Old Sep 26, 2011 | 09:00 PM
3.7 must be different. Nick just plugged his in and away he went.
Old Sep 26, 2011 | 09:01 PM
edumacate me then. I have a superchips flashpack which IS a custom tune, right?
Old Sep 26, 2011 | 09:32 PM
cheeseburger
he means you will need a tune that will make your injectors work like they should without running rich. A tune that was written specifically for your truck by someone that understands fuel maps and timing advance curves. that kind of custom tune. the tunes our superchips tuners are written to work with the factory equipment and nothing else. that being said your in a bit of a pickle because you need trans tuning and a custom tune..... thats got to suck.
Old Sep 26, 2011 | 09:51 PM
gotcha....definitely suckin a pickle on this one...
