Look ma no spark plug wires... WTF
Old Jan 1, 2012 | 03:33 PM
Originally Posted by marcsnyder05
That is what I mean. I don't see the point in disconnecting them if you have enough wire to work with
Ahh..gotcha. Yes, I had to disconnect the wiring also.
Old Jan 2, 2012 | 12:26 PM
Altair's Avatar
Altair
Dak attack!
Just be somewhat gentle with the coils, pull them straight up, don't yank them off to one side. If one gets damaged they aren't too cheap to replace. Also make sure you have a few short socket extensions on hand. Stacking two short extensions makes it much easier to get at the passenger side rear plug due to the limited room you have there (Place socket on one extension, lower in partially, attach other extension and ratchet).
Old Jan 2, 2012 | 03:19 PM
rapta619's Avatar
rapta619
Mines nuclear powered. I thought they all were!?! —_—
Old Jan 3, 2012 | 10:27 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
You have to loosen the A/C line brackets too to access the coils for, I think its, cyl. 3 and 4...
Old Jan 16, 2012 | 09:36 PM
ericemery's Avatar
ericemery
Retired Administrator
Hall of Fame Member
Bolts right.
Rich, I just used a 10 inch extension. I didnt have any issue getting a full extension down in the pass rear.
