How does the digital shift indicator work?
Old Jan 23, 2012 | 08:28 PM
MikeRWK's Avatar
MikeRWK
Default How does the digital shift indicator work?
Does it get its signal from the trans or a switch in the steering column?
Old Jan 23, 2012 | 09:27 PM
erau's Avatar
erau
SENSOR-TRANSMISSION RANGE
DESCRIPTION
The Transmission Range Sensor (TRS) (2) is mounted to the top of the valve body inside the transmission and can only be serviced by removing the valve body assembly. The electrical connector extends through the transmission case. The Transmission Range Sensor (TRS) has four switch contacts that monitor shift lever position and send the information to the PCM.
OPERATION
The Transmission Range Sensor (TRS) communicates shift lever position (SLP) to the TCM as a combination of open and closed switches. Each shift lever position has an assigned combination of switch states (open/closed) that the TCM receives from four sense circuits. The TCM interprets this information and determines the appropriate transmission gear position and shift schedule.
GEAR SELECTOR INDICATOR
OPERATION
The electronic gear selector indicator gives an indication to the vehicle operator of the transmission gear that has been selected with the automatic transmission gear selector lever. This indicator is controlled by the instrument cluster circuit board based upon cluster programming and electronic messages received from the Powertrain Control Module (PCM) over the Controller Area Network (CAN) data bus.
On vehicles with an automatic transmission, the PCM continually monitors a hard wired multiplex input from the Transmission Range Sensor (TRS), then sends the proper transmission gear selector status messages to other electronic modules over the CAN data bus.
Check out the sticky with the Service Manual link. A real lifesaver.
Old Jan 23, 2012 | 09:34 PM
MikeRWK's Avatar
MikeRWK
Thanks I have the FSM but never remember to use it.
