4.7L High Output spark plugs
Old Jan 27, 2012 | 07:49 PM
varnerhba's Avatar
varnerhba
it might be .35 maybe .40 for 4.7 i cant remember, kent maybe you should try the laser, maybe thats the difference between 25 mpg to yours.....just my 2 cents.... you get my pm?
no misssing idles like a cadillac....
Old Jan 27, 2012 | 08:10 PM
scjeep4.7HO's Avatar
scjeep4.7HO
I thought I would try the cool "new" E3 diamond fies and literally melted them. Same boost same abuse and my NGK's didn't even get phased. But in the end of the day choose the ones you like.
Old Jan 27, 2012 | 08:14 PM
varnerhba's Avatar
varnerhba
i run ngk in everything, literally EVERYTHING from a lawn mower to my dirtbike.....best performance you can get is those laser ones, im telling you!!!
Old Jan 27, 2012 | 10:57 PM
Designer's Avatar
Designer
Autolite 3922, I'll start there, cheap and suggested by autolite. If they start causing problems I'll switch back to plantium.
Old Jan 28, 2012 | 01:36 AM
varnerhba's Avatar
varnerhba
try doing the math with miles and check your gas mileage....let everyone know the results!@!! please
Old Jan 28, 2012 | 02:03 PM
Designer's Avatar
Designer
Currently getting 16 to 17 mpg. Will be easy to figure. Ill report after 2 or 3 tanks. Pulled Champion out when I swapped. All the plugs removed were properly gapped. They still looked good.
Old Jan 28, 2012 | 02:17 PM
varnerhba's Avatar
varnerhba
evidence of good plugs, i would of gone to iridium, i had the champions for a long time and they even worked good, my ngks are just so freakin sweet.
Old Jan 28, 2012 | 02:36 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
25 mpgs, with a V8, eh?
Old Jan 28, 2012 | 02:40 PM
varnerhba's Avatar
varnerhba
25.7 to be exact if its perfect conditions going down the fwy yea i can clock it ill take a picture next time.
obviously when my throttlebody is clean, air filter, new oil yada yada yada
Old Jan 28, 2012 | 04:07 PM
novovictus1's Avatar
novovictus1
my quad cab with a 6 speed got 19mpg once all hwy lol. I wish i could get 25! my mazdaspeed 6 got 24mpg regularly and that was poor from the turbo and lead foot. i wish i could get near that now!
lghtngblt02, i see you are in lemoyne! i commute to harrisburg everyday for work, and i see the capitol building in your signature pic. we should meet sometime.
