Wheel Bearing/Hub Experience?
Old Feb 15, 2012 | 12:39 AM
Eimer123's Avatar
Eimer123
Default Wheel Bearing/Hub Experience?
Has anyone replaced their hub assembly with anything aftermarket?
If so what brand did you use, did you have issues?
I have heard good and bad about Timken
I have head a lot of good about SKF
Old Feb 15, 2012 | 08:38 AM
thunder98110's Avatar
thunder98110
i got the cheap ones at napa. so far so good.
Old Feb 15, 2012 | 11:25 AM
rengnath's Avatar
rengnath
I was going to go with Moog when I thought about replacing mine. I started getting a wierd vibrations when turning the wheel after I replaced a half shaft, and the wheel bearing was the only thing that seemed logical was the wheel bearing, but then the issue resolved itself within a few miles of driving.
Good thing though because the bolts holding the wheel bearing on were all seized and I couldnt squeeze an impact gun in because the control arm was in the way to get the socket on them.
If you want Moog, try to see if theres a Advance store that has them instock where you can order online and do an instore pickup. Order them seperate and use code ES123. They should come to about $118 each plus tax.
Old Feb 15, 2012 | 06:42 PM
Eimer123's Avatar
Eimer123
Just bought the last 2 SKF's on Ebay for $220 free shipping.
Old Feb 21, 2012 | 11:19 AM
superdak05's Avatar
superdak05
both at napa for 350.00, came with 3 yr 36000 mile warrenty too, easy to swap out
Old Feb 21, 2012 | 01:37 PM
Eimer123's Avatar
Eimer123
Originally Posted by superdak05
both at Napa for 350.00, came with 3 yr 36000 mile warranty too, easy to swap out
Did you end up removing the knuckle? I remember having to on my 2000 Dakota. Not sure what is in the way on the 2005 yet. Dealership did the last 2 sets under warranty.
Also I will be doing a nice Write Up for everyone.
Old Feb 25, 2012 | 06:09 PM
Eimer123's Avatar
Eimer123
Wheel Bearings are on!
What a rusted pain in the ***.
Will have a write up soon
