4 plug tmr mod
Old Feb 27, 2012 | 10:37 PM
varnerhba's Avatar
varnerhba
Default 4 plug tmr mod
anyone on here or know some one that has a 3 plug jtec and seperate tcm? need a vin # so i can compare harnesses so us NGC 4 plug guys can completely remove the torqe management.
Old Feb 27, 2012 | 10:49 PM
not sure what your asking. I have removed all tm using my superchips.
Old Feb 27, 2012 | 11:16 PM
thunder98110's Avatar
thunder98110
yellow wire with the green tracer. pull it.
ive seen it done on a hemi with ngc. not sure if it will work for you but you can try. not sure why you would want to since you can get superchips or sonnax.
Old Feb 28, 2012 | 03:14 AM
varnerhba's Avatar
varnerhba
tried it with my 4 plug, didnt work, so im trying to find out some more info, can i have your last 10 of ur vin thunder?
the reason i am doing this is because i dont want to have TM off at all times, i want to be able to have my someone hop in it and not do a 360 in the oily wet asphault out here, so i would like to put a switch between my TMR wire, so what im trying to do is locate pin #10 and find out exactly what wire that is on a jtec/ seperate tcm, and compare it to a ngc.....
and i know SC gets rid of TM, but i herd only 70%, and i want a quick option either "on" or "off" kinda like a ESP button...
Old Feb 28, 2012 | 12:17 PM
thunder98110
the tmr mod is only at WOT. i dont see how giving you my vin number would do anything. just get on ebay and find a 2G dakota for sale they will have the vin # listed.
