simple question
Old Mar 23, 2012 | 11:40 AM
norma jean's Avatar
norma jean
Default simple question
whats the hot wire for the running lights?
I put my fog lights back in, but now the drivers headlight doesnt turn on, before i didnt have the hids, i tapped in to the low beam on this headlight. So I'm assuming its affecting it. I put the PIAA 55w=110w which makes the light be an 85 watt, theyre are pretty bright.
thanks for the help
Old Mar 23, 2012 | 12:20 PM
rengnath's Avatar
rengnath
I would assume you're running the PIAAs and HIDs off of relays? If not, that could cause some issues.
The wire(s) I used for running lights are the ones heading to the directionals. You should have 3 wires going to the socket each. 1 ground, 1 running light, 1 directional. I can't remember what color it was, but I just used a volt meter and turned on the running lights and directional to determine which one I needed.
Old Mar 23, 2012 | 02:22 PM
norma jean's Avatar
norma jean
The piaas have relays and the hids were plug and play, didn't need the relay, so I'm assuming that's why I'm having troubles, but I figure it'll be easier to switch that lead than put in a relay
