adding electric windows
Old Aug 16, 2005 | 07:00 AM
flyrodder's Avatar
flyrodder
Default adding electric windows
When I bought the truck, power windows didn't seem that important. Now I wish I had spent the extra bucks.
Is it possible to add these on now?
Has anyone done this before, and what is involved.(time,effort,expense)
Old Aug 16, 2005 | 10:16 PM
Drakkon's Avatar
Drakkon
Default RE: adding electric windows
check out your local junkyard for totalled models of your truck...if the door is still in good order with motor/window inside all you will have to do is rip the wiring out and transfer it all over...repaint the door most likely...rewire to the fusebox...probably a good 15-20 hour (baring the repaint) 1 man job...and from the junkyard doors should only cost like $500-1000 so long as its a you pull deal...
