Lifting 2wd
Old Jun 1, 2012 | 07:02 AM
kjpark's Avatar
kjpark
Default Lifting 2wd
Hey guys hows it going, i just got an 06 dakota v8 quad cab slt 2wd about 2 months ago and want to start lifting it soon. Just have a few quesitons since im new and all. I've read a lot about sapcers and body lifting so here it goes.
1) Since im a 2wd i here that i can go higher in terms of coil spacers compared to 4x4 dakotas. Is it ok to go with the 3" coil spacers? or is that still to high for 2wds. I know about the issue with wearing down front end components(i dont mind changing), i figure 2" and 3" will be the same for a 2wd as far as waering down and such(correct me if im wrong).
2) if i were to do my own 2" body lift, do you think i would need a steering extensions? Also I noticed that even for a 3" BL no brake line or gas filler extension is needed(someone please confirm this), all i would need maybe is radiator extension.
can't wait to do more, i love the truck. Its a big step up from my old compact truck.
Old Jun 2, 2012 | 04:44 AM
KingsDodges's Avatar
KingsDodges
automatic tranny or manual?
i have a manual i went with the 2" lift bcuz i was told that if i went higher it would mess with my shifter and wat not....
Old Jun 2, 2012 | 05:33 AM
marcsnyder05's Avatar
marcsnyder05
With the PA 3" body lift you get radiator extension bars and a steering extension and a brake box mount thingy but no extension for the lines themselves is needed because of the brake box mount thingy. There really isn't a need for a filler tube extension. Hope this helps
Old Jun 2, 2012 | 06:20 PM
kjpark's Avatar
kjpark
im an auto trans., so i don't think i would have the same problem. and marc thats helps a little, is the brake box mount just a bracket, or does it just relocate the brake box?
Old Jun 2, 2012 | 06:39 PM
marcsnyder05
It moves the box up off the frame a little here is a pic
Old Jun 3, 2012 | 01:20 AM
kjpark's Avatar
kjpark
ok i see it now. Thanks for the picture. I hope to tackle on the BL soon, i found blocks that i can get already, just need to fab up the brackets soon now.
