How to choose wheels
Old Jun 14, 2012 | 09:45 AM
kjpark's Avatar
kjpark
Default How to choose wheels
Hey guys I need some help on picking some new wheels. I've been reading a lot. I couldn't quite find it all. Is it true the offset of wheel must be +15 to +20or it wont fit?
I found some pro comps that have 4 inch backspace and 0 offset so I'm wondering how that will fit.
http://m.summitracing.com/parts/pcw-52-6785
Few more questions :
1)Anyone have these on? /What wheels are you using?
2)Also is it true that I will need some sort of ring adapter to go in between the hub and wheel since only stock wheels are hub centric and aftermarket are all lug centric?
3) what's it our hub size? Do I need to worry about this since they will be lug centric wheels anyways.
I have an 06 quad cab 4.7l v8 2wd btw,
Thanks guys
Old Jun 14, 2012 | 01:23 PM
MitsuRaider's Avatar
MitsuRaider
discounttire.com has a pretty neat tool that shows what the wheels look like in your own set up.
Whether you buy the rims from them or not at least you see what certain wheels look like in your truck
Here is the image they rendered for me:
And this is the trucks with the wheels installed:
Old Jun 14, 2012 | 03:11 PM
dakotaff's Avatar
dakotaff
Stock wheel offset (16x7 or 16x8) is 25.4mm, a zero offset pushes the wheel out about an inch.
So the area where the tire would be at it's highest, and possibly rub (depending on the tire size), would be pushed out. Meaning the front splash guard and front bumper fascia would be the possible 'problem area'. Trimming those areas would be very visible.
Dakota wheels are hub centric, which means the hubs support and center the wheel. Without the hub centering rings, the wheels could be off center. Even the slightest bit would cause vibrations and shaking, usually noticeable at higher speeds.
Dakota hub size is 77.8mm.
Lower than designed offsets can put added stress on the wheel bearings and other suspension components.
Old Jun 14, 2012 | 06:53 PM
kjpark's Avatar
kjpark
if i understand correct, the added stress of the 0 offset would kind of be the same as if i were to get spacers on the stock wheels right? Both causes the wheels to stick out further than normal being why. That being said i should have no problems fitting on the wheels as long as i get some hub rings?
Old Jun 14, 2012 | 08:05 PM
dakotaff's Avatar
dakotaff
Sure, the wheels will fit.
Old Jun 14, 2012 | 08:35 PM
damyankee84's Avatar
damyankee84
This site should give you most of the info you need about wheels... https://www.rsracing.com/tech-wheel.html
Old Jun 14, 2012 | 10:38 PM
kjpark's Avatar
kjpark
cool, thanks guys. I think im going to get the pro comps whenever i get my leveling kit. Hope the calipers don't get in the way, heard its a possibility, hope not..
